The periodic timer value returned NULL. Could not allocate memory
Check timer parameters for LACP module. Check the memory statistics. Otherwise reboot switch. show memory process lacp show lacp member-port <port> {detail}
Critical
Failed to create LACP periodic timer. port: %portId%
| Name | Type |
| portId | String |
